Hi All
Has any one replaced the rectifier diodes in the rectifier unit in their mig?
It’s a simple thing to do but would like to check the maths first just to make sure that I am using the correct diodes.
Thats once you have worked out which way the diode is bolted in ie anode or cathode. Mine is anode..
There are 8 diodes, 4 per phase. They were placed like this to reduce the current and voltage flowing through one diode.
If the welder is a 150 Amp, 240volts, each diode could be 40Amp 100v, because four in parallel together would equal 160 Amp 400Volts..
Cheers
Cheers
