You might get caught fiddling with your knob.....
Ooops. I'd wager you were using your phone while driving there....!Doesn't get much better than this IMO, peak design
Indeed, I've gone away from speccing pushbuttons on control panels as well, makes sense. Not so sure for cars though...I’ve just done 4 big control panels for materials testing in a lab, their previous ones had a jumble of panel mounted controllers, buttons, potentiometers and indicators - we’ve replaced them all with a big HMI - the only buttons they have are an e stop and a couple of reset buttons.
The beauty is if they want anything adding in the future it doesn’t need any extra wiring, cut outs etc. It’s also much less confusing to look at, with all the info easily displayed. I’m not sure it totally works as well in cars, but there’s likely no going back now!
Look at the new Volvo system, yes Volvo, the safety kings! The system is astonishingly bad….
skip to 1m20s to get straight to the issue and avoid intro
I'll never understand the all black thing. For the last few months I've cycled to and from work in the dark every day, the number of people I pass wearing grey or black with no lights astounds me, it's like they want to be ran over.![]()
So all the stuff that should be in front of you is now on an I pad ?
No.What is the difference between a touch screen and button.
You can learn both intuitively in the same way I can type without looking at the keyboard on my phone.
The same as I can type on a Physical keyboard
Friend of mine built a hot rod/race cat out of an old Fraser Nash and has used an iPad for the instrument panel. There is a wiring attachment and various apps to do the job easily enough, plus he can customise which dials go where, what size and style they are, adjust the parameters for warning lights etc. All touch control as well.Totally agree - I design HMI for work and for a control panel it’s really easy to add another button to a HMI, whereas a physical button needs holes drilling, wiring, inputs etc
But that’s on a control panel in a factory where your not moving and it’s the only thing you need to concentrate on. in a car physical buttons win every time, but stick everything in a screen and I’d bet it reduces the wiring and assembly times dramatically.
ThisI think the big problem is that to access functions you have to go through other sub menus - so a physical button requires a brief glance away, whereas a touchscreen can require several, often in different screen areas
