6.0mm will be okwill i get away with 6mm t & e cable (or do i need 10mm) for a 8.5 kw shower , run is about 12 m 8m threaded thru floor joists(no insuation) remaining 4 m chased into the wall.
Wired via a pull switch and 40 amp mcb and rcd of cource
cheers mike
clipped direct or in an insulated wall . over an insulated ceiling so drilled through beams and the last 4m buried in wall and intermittent use 6mm will be adequate I would second that
however I would suggest going up to 10mm in case of future upgrade/replacement... cable costs nothing more really, its all in the work & making good.
future upgrade that is a good point then you are not limited to certain shower units![]()
