MattF
- South Yorkshire
Toilet / wash hand basin in a garage is a great addition.![]()
Can only see a throne. No sink?
Sink is on the tip of the toilet, an all in 1 jobby to save space leaving me with more clutter space
Coming on really good...looked at bit mean there on the rubber adhesive
Time will tell, it is only small but its purely to wash my mitts after a visit to the loo, and potentially abit of metal dust at times. I don't have a link I told the plumber what I wanted he sent me a few pics to the ones he could get and hey presto it appeared. Quite a popular thing for under stairs etc.I thought so. Seen that idea before. Is it really practical having having to reach over?
Would you have a link to it btw, considering one for an outside WC.
No heat in toilet but a thermometer will be in there and as soon as it starts getting to the frosty temps il be knocking the water off in there and draining the pipes.Are you fitting some kind of heat in the toilet, for those really cold snaps….frozen pipes are messy!
Yeah I was and still.am.abit skeptical about how much water based glue was actually used. But again time will tell I guess.Coming on really good...looked at bit mean there on the rubber adhesive
That would work, but a strip of upvc trim, glued on, foam the back, then upvc on the inside too.I'd thought about timber and although it would take along time to rot I don't want the risk/hassle..
So plan is to get either some box section made up the correct size with a plate spot welded to the front then coated to match (as close as can be) then on the inside bolt/rivet a panel to it, so it would look like the actual beam that's meant to be there.
I will see though
There alot sturdier than the "secure" doors offered by the likes of other garage door companies.Looks goood Paul can I ask whose doors did you use and are they as solid as they look?
