Fairly pathetic I can't do this myself, but when you haven't got the right tools, you haven't got the right tools
It is a small block of steel 35mm x 35mm x 9mm with a 5.5mm diameter hole drilled right through it. Hopefully the sketch describes it well enough.
If for whatever reason a 5.5mm diameter hole is tricky, not a problem for it to be 6mm diameter. However, the centre of the hole needs to be exactly in the centre of the face.
Many thanks in advance if anyone can help. Please could you post in the thread or PM the cost incl. P&P to GU15.
Richard
Richard
