Would the steel liner for the Clark welder in the on line weldequip shop work for the SIP welder ? . I have been trying to ring then but cannot get through
Following a suggestion on this forum I fitted a net curtain wire from Wilkinsons. It only cost 80p so I figured, why not give it a try too? The brass ends unscrew from the original plastic liner and screwed over the plastic covering of the net curtain wire perfectly.
My 0.8mm wire now feeds through with much less tension on the drive rollers.
