Watts divided by volts
10W ÷ 240V = 0.0416666667 AmpWatts divided by volts
So a 5amp rated flex will be plenty.
The smallest fuse I have for my plug is a 3ampYea,
Or 41 miliamps (as its probably easier to find a 50ma fuse than a 0.05 amp one..)
I have a 3 core flex with a bulb holder on the end with a 10w LED GU10 fitting. Nice and bright above my head for reading?What are you doing ? / Installing ?
View attachment 422734View attachment 422735View attachment 422735
What was the wattage of the LED bulbs?That should be ok,
I had a normal 6-bulb unit in my kitchen and I replaced the bulbs in that with gu10 led.
Although the bulbs blow fairly regularly tripping out the rcd. They go off with quite a loud pop and occasionally blow the glass bit across the room.
They most often seem to go when first switched on so I think if I had one above my head I might put the switch somewhere that I couldn't turn it in when I was sat underneath it..
