Welds look good, what machine do you have?Making a bench on my new bench.
Was pretty gormless going about it. I welded three legs on like this, sticking up in the air, which was a chew.
After welding the third leg on, I realised it was much easier to fit them like this, on their side with all the support from the table. In my defence, I am not used to the luxury of a worktable.
All four legs in contact with the floor at the same time. No evident rocking, either. Must be doing something right.
The picture below demonstrates that I can still use the bandsaw with long lengths of tube. They fit under the table drawers with decent clearance. This is handy and something I hadn't considered when building the table
A fence post offcut makes a good spacer and support.
I didn't need to weld every join but I needed the practice, so I did anyway. My fillets are much tidier than my butt welds. Every joint was welded in the flat position. I had a good work out moving the frame to achieve this. It was lifted on and off the table a few times. A four-metre torch helped to get round it too.
Still need to add tabs to secure the top. Nuts and plates need welding on for adjustable feet. The bench will get a set of drawers too. No handles this time. Just a slightly deeper plain front so there's a lip to pull on from underneath. The drawer fronts will be flush with the frame this time as well.
Norm.
