- UK
Kitchen extract.... Over-hob extracter with a charcoal filter. Spark says to put an extractor in, says it needs to be 150mm dia. Does it need to have an over run like a bathroom extrator?
If its on an outside wall then fit a grill and ducting through the wall...it's like night and day for extracting cooking smells and fumes going outside compared to recirc through the Charcoal filter.Kitchen extract.... Over-hob extracter with a charcoal filter. Spark says to put an extractor in, says it needs to be 150mm dia. Does it need to have an over run like a bathroom extrator?
no chance of piping under the upstairs floor between the joists to the outside depending on which way they goThe over hob extractor is on a party wall so can only be a charcoal extractor unfortunately. I know what you mean though![]()
no chance of piping under the upstairs floor between the joists to the outside depending on which way they go![]()
Difficult job, if not impossible.no chance of piping under the upstairs floor between the joists to the outside depending on which way they go![]()
If a over hob extractor is used can I do away with a seperate extractor?
Theres usually a way with enough messing about, the rectangular ducting is very neat!
ok if your outside wall is one way or the other and there isnt a door in between
