Burdekin
Chief Bodger
- Aberdeen
I have a problem child radiator that isn’t working and gone through probably the obvious things.
The rad to start with was totally cold and both pipes.
I bled it and some air came out but no difference.
I turned off all other rads and didn’t make a difference.
I replaced the control valve and no difference but some jelly muck did come out, not a lot.
Both valves seem to work but isn’t a lot of flow but seems normal at the top bleed nipple.
I isolated both valves, removed the plug fitting the bleed nipple screws into and then opened each valve individually and got a big expel of air and gassy water from each. Refitted thinking maybe a big air lock was the reason but still not hot, but the line in is now warm, not hot but warm. The exit line and valve is still cold and the rad is not warm.
Could it be just a gummed up rad and I should replace or is it worth replacing the lock shield valve first?
Any other ideas. I’ve bled all the other rads and they are toasty warm. The one not working is upstairs and furthest from the boiler.
