mtt.tr
- Essex/Suffolk border
That hole / slot are your impulse.
If you have some inner tube put it between the carb and the manifold the bolt it down
Here is the correct adapter
www.lsengineers.co.uk
Don't forget the test under pressure and vacuum, also recommend turning the crank whilst under pressure or vacuum see if an a leak is created.
Once completed and everything back together measure the compression.
For setting up I highly recommend a tacho ( I do occasionally do mine by ear but always have them a bit rich until I can be sure with a tacho)
I use these,
The pickup wire I have wrapped up as a coil that I slip over the spark lead, will photograph tomorrow.
Pressure Testing Plug M10 for Husqvarna 336, 543XP Chainsaws - OEM No. 503 84 40-03
Pressure Testing Plug M10 Genuine Husqvarna Part. OEM No. 503 84 40-03. Suitable for the Following Applications: 550, 560, 576, 543XP, 543R, 553R, (243R, 253R), 535, 336
I use these,
