A couple of quick questions about a new roof on the garage. It currently leaks like a sieve and is fibre cement (maybe asbestos but if it is I’ve got all the gear and been on countless courses so I’m familiar with how to deal with it) so it needs to go. Garage is a pre-fab one.
I’ve got hold of some second hand, (but in reasonable condition), insulated panels 80mm thick which are 8m so will span the whole length in one run but need trimming. Is there any paint recommendations for this material to seal the cut edge? I’m not sure the wife likes the colour either, so can I over paint in a different colour?
Next question, the current fall runs towards the back. Is there a reason why I couldn’t change this so the fall is towards the front? I understand rain will run off at the door end, but there is a drainage channel in front of the door and guttering should catch most of the water? I could really use the extra height at the back.
When installing the new panels, should I seal the overlaps or is it not worth bothering?
Finally, the current angle iron beams are spaced every metre-ish. That should be sufficient for supporting the new panels?
Thanks
Thanks
