weldingnovice
- Northeast
Mk 8 jumbo front cable has snapped in the cab, is it a seat out job to get at it?
Cheers
Cheers
I had one apart today, and as said the plastic cover literally come of up and forwards.
This was on a 2016 model, got to say build quality/finish is a bit crap, starting to rust all over incl the brake pipes, I would be peeved if it was mine.
ftfyStandard transit over 5 months old.
I was also doing pads and one caliper as rubber boot had split and piston seized, but whilst under there I noticed all the edges of the factory underseal was coming adrift.This is why i only buy Sprinters.
(That said, they are partial to a bit of body rust.)
Looked at sprinters they're just as enthusiastic about corrosion as a tranny.This is why i only buy Sprinters
I could be wrong here as I did not pay that much attention, but I think it is actually a rod back to the two hand brake cables in the chassis?Upper and lower covers pulled off with a bit of effort, lower was tight against the seatbelt anchors.
Haven't got the new cable yet to look at yet, but it looks as though the cowling on the lever has to be removed to get to the cable connection.
That doesn't want to come off, it's in two halves vertically and screwed together from the passenger seat side with no access unless the seat is removed.
