finyuk2005
So i am trying to upgrade an older Logic flail mower (MF120) for behind the quad bike, trying to convert it from a single Vee belt and centrifugal clutch, to a double vee pulley and an idler to tension the belts.
The newer mowers use 3 belt pulleys and a tensioner as they figured out that centrifugal clutches are rubbish for this application!
I was hoping to use the bottom pulley from the slightly newer mower (MGF120) but its discontinued.
this gives you a good idea of what im looking at
https://uploads-ssl.webflow.com/5f7...9528d308d1518_logic-parts-manual-nov-2019.pdf (page 47)
My question is how would you get a pulley to grip the splines of the shaft?
I think i could just about squeeze the whole rotor in my lathe if it would only be possible to make a pulley of some kind fit by turning the splines off.
any ideas?
cheers!
any ideas?
cheers!
