Some consider it the likely causeThe thing is we already have bits of meteor, comets and other space dust crash landing on earth every day, it's already here and has been for 4.5 billion years.!
There's a good chance we are "aliens"![]()
i dont see the point in making a small station we have the technology to make better
as a spinning reference for artificial gravity spining capsuls on end of extending struts is too much weight
babylon 5 and the ark, the expanse used a spinning drum
the expanse used spinning plants within a drum for air
i dont see the point in building these when you can build a spinning space station with gravity
when these are far superior and simplier to build
only because they dont want to build oneI was reading something about this yesterday and apparently the problem with spinning space stations is that centrifugal force is still a thing in space and you're introducing a load of forces that would require much heavier construction than the current crop of space stations.
They could run at reduced gravity I suppose, enough to keep one's feet on the ground, and maintain some bone strength. Like the moon, which is 20% of earths gravity.I was reading something about this yesterday and apparently the problem with spinning space stations is that centrifugal force is still a thing in space and you're introducing a load of forces that would require much heavier construction than the current crop of space stations.
nasa,s own infoThey could run at reduced gravity I suppose, enough to keep one's feet on the ground, and maintain some bone strength. Like the moon, which is 20% of earths gravity.
Morning news showed a helicopter took it there as a sling load. Not the plane.I see that NASA used a C17 to get the 250g sample from Utah to Texas; looks like they wanted a safety margin.
Which I thought was stupid (using the copter)
EDIT:
Here is the news video I saw, and it's from BBC too:
I can only go by the article, and video, they only showed the copter, lifting it from the desert, and setting it down at a lab, where they opened it up.I think the copter just took it a relatively short distance from the middle of the test range to the nearest runway capable of supporting the C17 and the C17 took it down to Houston. As the final step in a project that cost $1.1B, and was ~20 years in the execution, use of a big 4-engined jet was probably money well spent? I wonder if a C17 carrying no significant load can get along on just one engine?
nasa,s own info
since this hasnt been tried in space its still only speculative
An artificial gravity level of 0.1 g can be achieved by a reasonably low rotation rate (5 rpm) at radius as low as 4 m (see Figure 2-04). Likewise at a radius of 4 m, about 15 rpm would be required to produce Earth gravity at the feet (although gravity would be 50% less at the head), or 21 rpm to produce 2 g.
so spinning a tube is more than ample enough to be done in space
the issue lies with the frame and also with the bearing and both can be beaten if you use roller coaster triangle frame work
as goes for landing on a spinning unit you dont want to be doing that so an extra landing platform can be built at any choice of point given
I didn't know that, I thought it was only the moon we had any regolith from, got any further information?
Yeah, they had a "lab in a tent" (set up to clean room standards) out in the desert, where I think they did a limited amount of disassembly, to get the sample container out of the landing capsule, then (I think) only that part went off to Houston. How far is Houston from Utah; I'm not sure but sufficiently far that I wouldn't put $1.1B in a single-engined copter to get it there (they often burn well when they crash)I can only go by the article, and video, they only showed the copter, lifting it from the desert, and setting it down at a lab, where they opened it up.
No mention of a air-o-plane.
. I believe that the picture of the C17 which I posted, was the actual one waiting to do the flight. I imagine air traffic control kept the sky well clear of other traffic as it went by.
