- UK
I have 9 of these LED lights on a circuit. Dimmer is as per photo. The lights flicker when near the bottom end of brightness. I'm aware of trailing edge/leading edge etc.
I have exchanged the dimmer module with a like for like and the problem still persists. I've gone round one by one taking a light off the ring, wago'ing the ends together and testing to see if a faulty light is causing the flicker - doesn't make any difference.
I did find one light wired with polarity reversed, but it still worked ok
There's two other lighting circuits in the same room, same lights, same dimmers, which work fine.
Any bright ideas?
Any bright ideas?
