The_Yellow_Ardvark
- Going Away.
Yesterday a keen, but not mechanical minded, member of the Alottment Shed took onto himself to winterise the tools and machinery at the Alottment shed.
We use a mix of diesel fuel and old oil. Hand tools and cleaned and wiped over with this mix.
The compressor is used to pump water from the sub surface tank, surface containers, drying stuff and inflating odd stuf
The member removed the drain tap, let the water out, very little. then poured in 2 cups of our fuel oil mix.
This was spotted and the compressor was taken to my place.
I removed the drain and the pipe from the pump to tank. Let as much of the mix drain out. I added Jizzer, 2ltr and gave the tank a good shake. This was done a number of times. Then as the instructions said, wash with water. I did this until the water ran clear. I repeated this 3 times.
I am now blowing warm air into the tank. I have checked the rest of the compressor and can not find the mix anywhere else.
My questions are:
What more can I do to ensure the compressor is good to be used?
What could of happening if the compressor was ran up?
Thanks.
My questions are:
Thanks.
