I'm eventually getting round to sorting the lathe I got off Cato and need an invertor. Is there anyone the masses can recommend ? for a good reliable unit rather than pot luck on E Bay.
I found them really helpful over the phone and in person, Bought a TEC 3ph motor and Parker brand VFD, mounting lug on my motor was broken in despatch, returned it in person as did not trust courier and not too far away , they replaced the motor mount and while I was there they gave me a bit of tutorial and we wired it up, them supplying the shielded cable and all. Good people.Inverter Drive Supermarket are another more mainstream supplier.
You'll need some more information on your motor. Such as can it be converted from star to delta, power rating, single/two speed. Are you prepared to do the work yourself or do you want a fully prepared package? Obviously cost will vary considerably.
Yes this is the type I fitted. The Steve Jordan you tube videos helped me greatly. I'm not an electrician but found it easy enough!I've fitted a fair few of the cheap chinese inverters over several years. Yet to have a problem, the only issue is deciphering the poorly written instructions.
Assuming you want single to 3ph, just search 'AT1 inverter'. (3ph to 3ph is an 'AT3' I think.
If you buy one from ebay, amazon or the like, you have to be capable of fitting it, it won't be a complete package like you might get from a reputable company so you'll get no support if you don't know what you are doing.
Need about 10 amps.What output are you looking for?
Need about 10 amps.
