Hiya, I learnt to weld earlier in the summer to get my mk6 Transit through its MOT. It failed on a part of one of the rear leaf hangers the year before and a local garage welded it for me. They used self tappers to pin a plate in and then welded it in (or so it seemed) before undersealing over it. I took the self tappers out as they were in my way - and it turns out they hadn't even f***ing welded the plate on. With the screws out half of the patch was loose (as you'll see in the video below). Underneath the patch looked exactly how it did when it went in the garage - rust and old factory underseal. Half of the stitching was directly on to factory underseal. So it just burnt/melted that and didn't touch the steel underneath. I was promised they would chop out the old metal and replace with fresh stuff. They didn't even grind the underseal off let alone the rust.
That is bad enough but they also did two much bigger bits at the same time on the chassis rails, directly above the axle. I want to take that back to see what's going on but if I uncover something awful setting up the weld station is a big job and weather dependent, and I need to be able to drive the van. If you discovered what I did on the leaf hanger, what would you do? I'm 100% going to complain and fight for a refund on that. But should I grind back the chassis rail patches? Or have it inspected by someone else? I'm far from an expert in motors or welding.
Thanks in advance. I don't think I could have pulled off my MOT without this forum. Absolute legends
Photos to follow
Photos to follow
