DennisCA
- Finland
It does add another layer of complexity to make a water borne system. I do however have a lot of PEX hose left over from 10 years ago when the house was built so I suppose one could put in the hoses at any rate to future proof it.
Re: the above video I don't like that the firebox seems to be in direct contact with water and is cooled down by it. The firebox itself should be insulated and made to be as warm as possible for maximum combustion efficiency. Then the heat should be extracted from the flue gasses later, as much as you can without getting glue gas condensation issues. You can go further of course if you can handle the condensate but flue gas condensation has typically been the real of industry.
I do think if I put a stove in I might just first go with a cheap Harvia heater. Terribly inefficient but you can improve that by cladding the firebox in insulating material and then increasing the convection surface area in the chimney to compensate for the increase flue gas temp.
If I could find one though, the best heater would a 2nd hand Porin-Matti. Compact, insulated, uses contraflow principle. Used in Finland for decades, said to have an efficiency of 86%.
Lumpy concrete mixed when it was snowing????
