Red'n'Black
- Malvern, Worcs
Hmmm you may struggle..... use all the patchesView attachment 416400
Well that made my ears ring a bit.
Top tip: make sure the tyre is properly on the rim on both sides before giving it some beans with the inflator...
Looks like I need a new inner tube, there aren't any patches in the kit big enough for that one.
Duct tape.View attachment 416400
When we were kids we liked doing skids which in turn wore big holes in the tyres, being poor dad used to cut strips of old carpet and put them inside the tyres to cover the hole!View attachment 416400
Applying Super glue to an inflated tube hole, was only 7, seemed like a good idea, stoke Mandeville eye hospital though otherwise... I miss my Raleigh TomahawkWhen we were kids we liked doing skids which in turn wore big holes in the tyres, being poor dad used to cut strips of old carpet and put them inside the tyres to cover the hole!
I have to say I dont know how we survived as kids the scrapes we used to get in!Applying Super glue to an inflated tube hole, was only 7, seemed like a good idea, stoke Mandeville eye hospital though otherwise... I miss my Raleigh Tomahawk![]()
Cut the top and bottom off and down the vertical joint ,they flatten to some nice copper sheet . It's what i did with the last cylinder I had just scrapped the coil well most of it .Wasted all afternoon cutting the top off a leaking copper water cylinder , I assumed it was hard soldered and would be an easy fix, turned out to be silver soldered probably induction brazed and i had to get the oxy propane on it to get the joint separated, it took so much heat to get apart that the joint is never going to solder again.
Straight in the copper scrap bin
This is exactly how I made the copper top for my bar, folded it over some kitchen worktopCut the top and bottom off and down the vertical joint ,they flatten to some nice copper sheet . It's what i did with the last cylinder I had just scrapped the coil well most of it .
And I always thought copper top was a ginger woman that went like she was Duracel powered!This is exactly how I made the copper top for my bar, folded it over some kitchen worktop
You never asked about my “Guest’s”And I always thought copper top was a ginger woman that went like she was Duracel powered!
Pictures…….or it didnt happen!You never asked about my “Guest’s”
Only to be shared on a different forumPictures…….or it didnt happen!
Which one www.rustybrillopad.comOnly to be shared on a different forum
Your guest's what?You never asked about my “Guest’s”
Gaoateye???Only to be shared on a different forum
