Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
You made that, I'm not going to ask...View attachment 416262
This is wooly
This is wooly
He's oop North, not Welsh....You made that, I'm not going to ask...
What do ewe thinkYou made that, I'm not going to ask...
Another project to use up my collection of scrap galvanized angle iron and cheapo buzz box welder.
I'm making a frame to sit on top of a trailer tent chassis to convert it into a flat bed. It will be fixed down to the chassis (haven't yet decided how) and boarded out using more scrap timber. I could either bolt straight through (and down) to join the two parts or weld some metal straps onto the bed and bolt into the chassis sides. The latter has the advantage of not having any bolt heads to interfere with the boards, and the two parts could easily be separated without removing the boards. What do you think?
Another question:
I've mitred the corner joints. The mitres are beveled and welded from both sides with full penetration. The outside corner has been knocked off with a grinder and welded closed. Would a professional welder also weld on the inside angle? I've not done so (yet) and wonder if it looks amateur.
Cheers.
Another question:
Cheers.
Poor lonely woolly tatty sheepView attachment 416262
This is wooly
I'd weld both sides not only for strength but to keep water out .Another project to use up my collection of scrap galvanized angle iron and cheapo buzz box welder.
Another question:
Cheers.
Thanks.I'd weld both sides not only for strength but to keep water out .
Nice idea, but I don't have one of those either!Power file?
Always better to have tools you don't need, than need tools you don't haveNice idea, but I don't have one of those either!
Always better to have tools you don't need, than need tools you don't have![]()
Paint it in acid paste then power wash it away and once dry , weld pick off the slag when stone cold then cold galv spray it ?Thanks.
I happened to meet a welder earlier today and I asked for his opinion. He said he'd weld it closed. Also said I hadn't ground the galvanized back far enough.
So, how am I going to remove that galvanised in the inside corner? Can't get in there with a grinding disc. I don't have a die grinder - do I need one?
Looks good my friendFirst try at knurling, M6 thumbscrew, made the shoulder a bit too long, bit of a test.
Happy with the knurling tho, well grippy!
