make the base a touch smaller than the shed and drop the tin sheat over the side that way the water will never come inSilkolene did not smell as good as castrol R..
Yeah did consider this, just wondered if there’s any other waysmake the base a touch smaller than the shed and drop the tin sheat over the side that way the water will never come in
might help to slight slope to help remove any condesation
That's how I did my wood workshop.make the base a touch smaller than the shed and drop the tin sheat over the side that way the water will never come in
I have one of these steel garage / workshop with the Z profile over the edge of the base and behind the cladding. Works perfectly, no water ingress.You can get no drip base profiles that go behind the sheet, and over the edge of the base.
see pictures in this link
Pardon our interruption...
www.ebay.co.uk
How is it fixed to the cladding?I have one of these steel garage / workshop with the Z profile over the edge of the base and behind the cladding. Works perfectly, no water ingress.
It goes in behind the sheets fixing for sheets go right throughHow is it fixed to the cladding?
Tec screws through the cladding, profile and into the galvanised frame.How is it fixed to the cladding?
Did think of doing that but with kerb stonesJust put a course of bricks all the way round inside the cladding. It's dead space anyway.
Engineering bricks or concrete blocks are cheaper. Kerbs are around a tenner a kerb at 0.92m long. Concrete block is about 2 quid for 400mm. We some times use hollow blocks with rebar chemfixed into the slab and filled with concrete so noone can do a battering ram job on the building. Or concrete panels for a really thorough jobDid think of doing that but with kerb stones
