I've already got citric acid i use for my derusting tank, how do you use it for cleaning big items you can't dip ?There have been quite a few threads on here about using citric acid solution to remove rust, and that may well be the safest and cheapest way of doing it. In the past I've often commented that you can buy citric acid as a powder at Wilko's, but sadly, that option may be ended but it's available on eBay.
Re "Pickling paste", pickling of stainless steel often refers to the use of a mixture which includes hydrofluoric acid, which is seriously dangerous stuff and does attack not just the rust stains, but the stainless itself. I think it would be overkill for what you want.
Yes, a soaked sponge should work. I think I'm right that citric is about 40 times more acidic than acetic ( but still a very weak acid) and citric does not smell. I once visited a workshop where they were using lots of vinegar to clean some big steel vessels - after a while the smell becomes a pain in the bum.Soak a cloth or sponge/piece of foam in it and leave on top of the stain. Wrap with clingfilm to stop it drying out. Come back in the morning.
White vinegar is also good and might be cheaper than citric.
How to clean these marks off a stainless tank where its been in contact with mild steel ?
( Can't blast it )
Totally agree the strip and clean 3M scotchbrite wheels are great,Yeah the crap on the stainless in the first post, i wouldn't have thought citric would touch it. Even nitric acid pickling paste would take a while. I think you did the right thing in abrading it off. Poly abrasive wheels work great on stainless, at least the 3m blue ones do.
White vinegar in the UK is usually 6 % , American stuff in their pickling recipes is often only 3 %Yes, a soaked sponge should work. I think I'm right that citric is about 40 times more acidic than acetic ( but still a very weak acid) and citric does not smell. I once visited a workshop where they were using lots of vinegar to clean some big steel vessels - after a while the smell becomes a pain in the bum.
What do you use for neutralizing?This stuff remove light marks....a mix of hydrochloric, nitric and phosphoric acids I think.
We tend to give everything a good wash down with that after cleaning welds with Antox or electro wand. Removes light rusts marks from forming, forks, benches etc.
Water![]()
I've just geared up for a load of passivating for upcoming work, I'm using a bymat electro cleaner, and a couple of different phosphoric acid based cleaning solutions. I'm going to use elmer wallace mainclean, its at 10% dilution ratio which makes it way more cost effective than other brands neutraliser. But whatever i do i need to avoid white staining.
