daxliniere
- North London, UK
Can a small granite surface plate be used as a square?
Yes, but over £100 for something I'm going to use only a few times, it's a bit rich. For an engineering shop producing parts to other people's specs; yep, absolutely. Worth spending even more, I'd say.Granite squares are available.
Yep i don't know if you've seen/used a granite square, but if you have then you'll understand why they don't make them like the surface plates 4-5" thick... weight. Imagine trying to repeatedly move a 30kg high precision/fragile block.Yes, but over £100 for something I'm going to use only a few times, it's a bit rich. For an engineering shop producing parts to other people's specs; yep, absolutely. Worth spending even more, I'd say.
I was hoping I could pick up a small used surface plate (<300mm) for cheap, but that's good to know about sides not being lapped square. Thanks for the heads-up, Brad.
Depends if you have a cylindrical grinder, a known good surface plate and a way of lapping the base.Cylinder square might be a more cost effective option. I don't know how true that may be (no pun intended) but it occurs to me they might be easier to produce.![]()
Thanks for the heads-up, Milkybars, but I'm good for now.@daxliniere It won't help your cause in relation to a sqaure but I do have a small granite surface plate going cheapish round in Ilford as part of project clear out
View attachment 415259View attachment 415260View attachment 415261
Old piston pins are great for many applications ,I found myself using them(35mm diameter x 100mm long) for setting up things on machines .Cylinder square might be a more cost effective option. I don't know how true that may be (no pun intended) but it occurs to me they might be easier to produce.![]()
Gudgeon pinOld piston pins are great for many applications ,I found myself using them(35mm diameter x 100mm long) for setting up things on machines .
They are precision ground on the flat surfaces too + they are hard as hell but they still not brittle since we use on the hydraulic press too
