Nice work.Made some little locking levers to replace some missing ones on one of my machines. Top one is original, bottom one I made.
Blimey. That’s an amazing finish for mild steel!Ordinary mild steel bar
I think the manual for this is at http://homeappliance.manualsonline.com/manuals/mfg/singer/29k72.htmlView attachment 414992
I bought an old Singer 29K (1934) and have been sorting out some timing issues. Seems a lot better. I cut up some leather scraps to make a Poppy or two, and a Keyfob thing for my father.
1.2mm stainless from the look of it. Need to make a valence similar to the black one. marked out with sharpie line followed by a scribe.
Need to leave about 2mm for the fold and chop a bit extra out of the corners so they don't foul when folded.
Oh and you got to get it right first time. eek.
My knife isn't long enough to form it in one go so I do the middle a bit, then gradually bring in the ends etc.
Worked a treat.
Nice clean bends and the press tool allows me to remove all the fingers except one that fits the channel for the last bend.
Rinse. Repeat.
It's for a neighbour and he tells me it fits a treat.
S.
That’s a nice job. I need to make something similar for the oven in our new house. My folder won’t form such nice tight bends tho unfortunatelyWell that was a blast from the past. Thanks for the "likes". I only respond since this property has changed hands twice since I made that thing and I am now doing odd jobs for the new owner. The kitchen has been remodelled and the appliance long gone so I was quite happy to recover this exact piece which the new owner asked me to dispose of for her...
That is a quality weld - especially when using an arc welder. I have looked at the final product whereby you have used the checker plate and 8mm steel . Beautiful !Not finished yet. Got to cut and weld the top (rusty sheet it is standing on) and cut/fit another shelf. All free scrap so far.
Using my cheap welder.
Thanks for the comment.That is a quality weld - especially when using an arc welder. I have looked at the final product whereby you have used the checker plate and 8mm steel . Beautiful !
So made the correct size one after.That looks superb!Airtight lid for 10 liter glass jar. I broke my head, but I figured out how to do it.
Silicone, Viton, PTFE gaskets and seals will be added later
View attachment 415187 View attachment 415188 View attachment 415189 View attachment 415190 View attachment 415191
My days of that kind of thing is long gone thankfullyThought I should contribute. Have left home, gone north about 1000km to southern Queensland for and engine replacement in a long liner. Out with the Volvo 163 and in with a John Deer, I think about 585hp at 1900rpm.
Had the engine mounts constructed several days ago, but needed painting and hardening so engine bolted down today and aligned. For those that are interested, alignment error down to .05mm.View attachment 415296
Starboard side view, rear mount also incorporates the bell housing and gearbox.
again for those that are interested a closer look.
What's left to do, oil coolers for the gearbox and the hydraulics, the exhaust dry extension to the water mixer which is on the the opposite side of the turbo outlet and the 'oper house' that will hold the 24volt clutch pump and the power steering pump. I expect to be here another week.
Not so bad if you are working with someone else but working on your own can be a PITA.Must admit that the owner is helping, but my legs hurt and are swolen at the end of the day. These are quite fun to do with the right customer, but as you say I am now really too old for this. This one will probably be my last. When I get back home, rest a week and then go south about 400km to complete the vessel that I did the hydraulic on. That job will be the chiller recirculating and distribution pipe work and the live bait distribution manifold and pipe work. After that I thing that I am done, too old and I like sleeping in my own bed with the events coordinator at home!My days of that kind of thing is long gone thankfullyNot so bad if you are working with someone else but working on your own can be a PITA.
