Hi all,
Sorry for long post but hopefully the info helps to help, I’m trying a cheap and cheerful respray on my daily driver. Using an Optiflow LVLP gun, I had results that I was really happy with in epoxy primer (1.8mm) and then Nisocoat 2 (1.4mm) over that.
Since then I’ve just not been able to get it to spray nicely, it’s way too dry. I’m a novice with a small budget which doesn’t help but I got a really good gun finish gloss with no effort or practice which is amazing for the project I have, so what I have should hopefully do the job if I can find where I went wrong?
As mentioned im using the Optiflow gun, I have a 50 litre 9.6cfm 2.5hp compressor, 9.5mm id 10mt air hose, and a regulator at the gun. I’m painting outside as it’s all I’ve got but when it worked the results were so good for me. I can’t remember how I had it set up when it worked well as I expected it to work that well the next time but just not been able to repeat it. I cleaned the gun with gunwash and brushes/needles after use, I mixed about 40% thinner in both the Lechler and Nisocoat
Thanks all for any input, pics from when I got it to work. When it didn’t it was very dry/rough :/
