God mode restorations
- uk colchester
The support bar for the cube is here but hasn't been installed yet just incase someone mentions it
Really enjoying your build - thanks for sharing.
Yes that's inside the cube. The cube can rotate to the left and right and can be locked in that position. I will take picturesReally enjoying your build - thanks for sharing.
I know nothing about shapers - but I think this is in the cube (I've been following..) but what does it actually do please?
I will be keeping it as the cost Would outweighs what the machine is worth....I have a bigger shaper that will be getting the same treatment but I have other stuff to finish firstNice job, are you planning to keep it and use it or move it on?
OK. In the pictures you will see the cube can rotate in both positions. Also the cube sides can be used for different things. The head on the shaper can be rotated to so you can get them in some remarkable positions
Yes that would be a good idea..Will probably do the sameThat V slot is pretty well useless until you drill a few holes either side to accept hole down bolts, somethig I've never got around to.
