Ross365
- UK
I want to examine the ABS sensors on my Celica, which is 21 years old. They are held in place by a 10mm hex head screw, but rust has taken its toll and a 10mm socket feels loose on the heads, so much so that I’ve not tried to get the screw out fearing that’s what’s left of the corners will fail. Access is restricted so I think a socket on a shaft is the only option.
I’ve ordered a couple of 6 point 9mm sockets, thinking that I can use the minidrill / attachments to open one up to a size that should fit more closely, especially when "tapped" on with a small hammer? In advance, I'm applying releasing fluid. The use of heat is out - too close to the sensor.
Any alternative ideas welcomed.
