AVI_8
- Prestwick
Hi folks, thought it was a bit too cheap to be true for what it is and that might appear to be the case, when I pump the pedal on this spring compressor the ram moves about 8mm up then drops back down, doesn’t appear to be a stuck release pedal as when the release pedal is pressed the ram won’t move when pumping it up, there’s no leaking fluid could it just be not enough oil?
there doesn’t appear to be a fill plug and was wondering if I took the big nut off the top and put some oil in it is that the correct way to top up the oil, it’s brand new, should just send it back but I need it to work as I’m stuck with a removed strut now.
pictures
pictures
