Noods
- Ipswich
Hi all..
Before anyone says it, yes, i’ve been a bit stupid here without doubt, for i had this decent bench grinder ( not an expensive one ) that was working fine but then got a more powerful one, anyway, removed from the bench putting masking tape on the wiring with the connections all marked up only to store it away for years and now having a use for it again find the writing has faded to nothing, can’t read it at all..
So, anyone have a clue how to wire this little chap up?
I’ve got a choice of two 230v switches a 4 terminal on/off rocker switch and a 6 terminal push on and off switch..
The bench grinder wiring is all sheathed as one and have two reds one black and one blue..
Normal 230volt supply obv live neutral and earth ..
Normally little electric jobs don’t faze me but this one has somewhat tbh, it’s the two reds coming out of the motor that’s confusing me, the blue i guess is the neutral and the black ?
Your help would be appreciated so thank you…
4 terminal switch… below
6 terminal switch
4 wire Bench grinder wiring on left 2 reds 1 blue and a black and 230volt supply right..
6 terminal switch
