Looking for a 13/16 AF wrench needs to be quality as I may have to thin it down and nut has short flats not the normal engagement any sugestions
Yep no worries, I'll be there on Tues or weds and have a look round at what's available, bear in mind you can grind as much off the spanner as you need to fit the job. I've got lots of butchered "custom" tools I've mangled to fit some awkward thing..Thanks @Porkypine & @8ob
Yes open ender will check what I can fit in the slot
Could I presume on you to run vernier over both ends of the jaw I really need a tight fit will take photo of part tomorrow
Stahlwillelook for Sarwhillie , they are the thinnest about ,, also 13/16 is a spark plug size and they are thin wall sockets if you can get one in ,,,
knew the spelling would be off ,,, yep , alloy steel and lighter and thinner than snap on , I bought a full set thirty years ago , well two sets actually , flat rings and deep neck rings , and they have been mighty , again they dont get used every day but wouldnt be without them.Stahlwille
Looks Good @8ob only slightly to fat the less I have to take off the better, a friend has said he has something that might do can I keep you in mind please, especially if the jaw are trueThere is a Gedore 13/16" here if you want it, its quite thin on the open ended,
Price makes SO look bargain basementWhy not ask the manufacturer of the part you intend using it on, if a regular thing, what spanner make they use ?
