I bet that weld could be broken with two fingers though. There’s obviously not enough heat put in to achieve much.![]()
They always are and have been. Takes a fair bit of kit to produce (and cool) a 5kW laser let alone a bigger oneI looked on the web for some info. its not really hand held, unless you call mig and tig hand held. the bit in the clip @TechnicAl posted looks like the business end of the machine. there a a massive "base unit" as the controller/power source.
I meant as opposed to a robot......all the lasers ive seen have been robotic.I looked on the web for some info. its not really hand held, unless you call mig and tig hand held. the bit in the clip @TechnicAl posted looks like the business end of the machine. there a a massive "base unit" as the controller/power source.
far from it I would imagine....Ah that makes sense. I doubt the will be cheap
Not really handheld, but here’s mine View attachment 203626View attachment 203627View attachment 203628View attachment 203629Wire in last photo is 0,4mm for scale
We have one at work. A quick t joint on 2mm steel could take my 15 stone jumping on it and it just bent. Really surprised me how strong it wasI bet that weld could be broken with two fingers though. There’s obviously not enough heat put in to achieve much.![]()
I'm waiting for the Parkside versionAnyone know when the banggood version is being released?
