It's not been on offer for ages, but Tesco have big straw cans at 3.85
OK if you have lots of wet things I suppose.![]()
You can buy it in gallon cans, 5 gallon cans, 55 gallon drums, and IIRC if you call and arrange it, by the tank car load.
You can always burn it for heat next winter.....Might be a bit excessive for my use!
Get the right ultrasonic fluid and you don't have to bother with any of that, just out the tank and leave to dry.Parts out the ultrasonic, rinse in fresh water, blow dry with compressed air, spray with wd40.
Not so much with the spray cans....
You would also be breathing in allot less of the vapors with dipping.Dipping stuff would be easier than spraying!
I don't normally buy it to be fair, it has limited uses, but when it's near enough half price it's handy to have a can of two around.
I'm hearing news about a tiny atomizing nozzle, and then someday paint will be sold in them...straw cans! what will they think of next?
With or Without an ignition source ?It's great for killing wasps, I don't use it for much else.
Done it many times, Carb Cleaner my favorite, Brake clean next.Without - a quick mist and it will instantly drop them out of the air. If you have never tried it, be prepared to be amazed.
Had a 5L container and spray bottle for about 15 years, still plenty left. Occasionally buy some of the better branded aerosols but when they run out I've still got the old WD to fall back on.I buy it in 5L and use with hand spray bottle find it easier to apply in those, about 30 quid last time, generally use it for cleaning and wiping down and with ali on mini lathe & mill.
