Cato
- Birmingham, UK
The swivel castors I fitted to the bench I made turned out to be less than durable. So does anyone have a recommendation for a source or make of castor which are suitable for using under a mobile steel bench? I'd say max weight including the bench will be 300 - 400 kg, wheel dia would need to be 100mm plus, the surface it's running on is an old brick floor, the top plate would need to be suitable for welding to the legs.
I'm not after the cheapest, I just want 'fit and forget' that will deal with the above.
