https://www.aliexpress.com/item/32826045278.html I fitted this to a clarke 150, had to wire in a brake circuit with the help of this forum to stop it running on and wasting wire everytime I stopped, made it useless for bodywork continuous tacking style welding too. I think I would have been better off with the type with the spur gears rather than the worm and wheel that I got.
Although the motor I got says 24v and 4A in reallity it is about 1A max at 28v while fully loaded manually and about 0.5A when feeding wire. I'm sure most wire feeds are chinese rated too and the power rating is the maximum power output or input not the actual power in use which will be somewhat reative to the load.
