dan.taylor.1
General Tinkererer
- Kendal, Cumbria
Hi folks,
Need 2 0f these for my newly acquired oxy fuel hose reel for the rotating spindles. I'm guessing they're just rubber as viton doesn't work with acetone so wouldn't be used in acetylene equipment.
Best I can measure they're nearly 23mm OD at the largest and 12mm ID at the smallest. Tapered side I side and out, 5mm thick and look very much like a symmetrical u shape hydraulic seal but I can't find any that fit.
The brass stub that goes inside is 12.7mm and the bore they go into is 22.0mm and the u shape fits towards the tapered bottom of the bore.
Any help much appreciated.
Cheers, Dan
Cheers, Dan
