Gazz292
- Scarborough
I have a 'SIP Stratus' direct drive V twin compressor, 50 litre tank..... and live in a residential area
i made a dog house for the compressor to live in that has quietened it down a bit... baffled air in and outlets to the dog house, with a fan into the exhaust air baffle that runs whilst the compressor is running and for 3 mins after it shuts off... so never had any overheating issues, but i think i got away with that as i would only run it one or 2 cycles a week,
I'm getting a plasma cutter so will suddenly need a lot more air, and i imagine i'll have the neighbours complaining soon if i run my current compressor continuously for 20 or so minutes at a time.
One day i'd like to get a small blast cabinet too, but i do mean small, and would only use it occasionally to clean the rust off small parts, this is all just a hobby for me.
So i've been looking at those 'new' compressors that have a motor and 2 short stroke pistons either end, oil free due to a teflon seal etc, but they seem to have fairly low air outputs unless you get one with 3 or 4 of the compressor units on a tank.
Then i saw this compressor : https://www.stahlwerk-schweissgeraete.de/brushless-compressor-st-1250-bl
Each motor runs 4 cylinders rather than the usual 2, and it claims 12 BAR pressure, and upto 500L/min (that's obviously when the tank is pressured to something like 1 BAR, and the real L/min output will go down as the pressure increases)
it seems that instead of pumping that tank upto 12 BAR then using a regulator to vary the outlet pressure, it instead pumps the tank to the pressure you set on the control panel, not sure that's a good idea... i have a pressure regulator inside my workshop anyway, so i'd just set the pressure to max on the compressor all the time.
And this 'brushless motor' bit, mains induction motors are 'brushless' anyway, so is this a DC brushless motor? it has 2 speed settings to vary the amount of noise it makes.
Obviously a lot more electronics to go wrong, this compressor has a 7 year guarantee, but i can see my current compressor still running fine (if noisily) in 20 years time, and it's already 15 or so years old.
