madkayaker
Pro sparkey Pro Welder
it can be pme on over head brightspark
72A @ 230V no good for a domestic!
and its not relying on the earth rod u said u had . in that case the rcd doesnt have to be back at source and can be in your garage . if u put the new supply into your garrage the welder can still be used but 50 amp would be max in your distribution board and would just trip if u exeeded it with no damage to wiring
.mine runs on a 30 amp fuse no bother . just make sure no ones having a shower when u are using it or any other large load it wont be a problemit would be hard to get the disconnection time for a 50A breaker of the characteristics needed for the welder on a domestic. plus if the house hold also used an electric shower or hob you could end up over loading the main fuse
mine runs on a 30 amp fuse no bother . just make sure no ones having a shower when u are using it or any other large load it wont be a problemits not the sort of thing u run constantly
Hello Mickj,
"I guess I should be grateful that it was desperately cheap then"
It won't be cheap if you still plan to try and use it. Upgrading the power and the amount it uses will soon make it a very expensive welder. It's also rated at 0.6 power factor which is not good, as it's power is just under 10 KW for nearly 16 KVA.
Alec
