Has anyone used a decent metal glue. Ill tell you about the application first.
My middle lad managed to lose the shoulder off his metal watch strap, you know the outer bit that hinge the metal strap and is joined by two pins. The factory part is pressed on to ribbed pins in two corresponding holes. Hopefully you get the idea but just in case Ive included a photo. Before you ask it was silly money to buy the new strap for the watch.
Now I made this part out of a SS nut that I cut down, shaped and polished. The thinest drill I had was a little too large to clamp on to the splined pins. My first attempt was with alradite. No luck after, a little while it came off. Stud grade locktite didnt work.
What I am worried about is that the sweat from a teenager will loosen the bond.
Any ideas?
Any ideas?
