dan.taylor.1
General Tinkererer
- Kendal, Cumbria
Socket maybe?
YupSocket maybe?
Not to quote my own post, but….
What is the female part of these called does anyone know? Ball clamp it isn’t and I’m getting results I’d rather not have in my browser history
I want the clamp arrangement that goes over the RAM ball and tightens up. Ideally with a flange mount but that’s the least of my worries.
All I can find is a double ended tube so as you can put a ball in each end but that’s not what I want or
Very nice work.The paint and fittings arrived for the painting tool box. First, 2 coars of primer and two top coats. The cheap builders merchant's ply on the front and back is really nasty but it will do.
The handle and catches arrived from Pen Elcon, they supply bits for making cabs for the music industry. Look pretty bog standard to me. I already had some cheap corner protectors but they were antiqued so painted them satin black. I wish I had painted the hinges black two, I guess I still can.
View attachment 400940View attachment 400941
Next onto fitting out the inside I have a few ideas. I quite like the contrast between the painted outside and wood interior.
Cheers
Andy
Today I made the camper van whole again.
I thought the battery tray would be the tricky bit but the DS lower inner guard was worse.
There was not much left for a pattern.
Forgot to take any photos during, but this is after a coat of white epoxy.
It's all a bit lumpy but it will do the job. I'll seam and underseal it after it gets its MOT.
Battery tray was similarly lacking in areas, so made my best guess.
I used 2mm steel but didn't have a bit big enough so I welded two off cuts together.
Mig was at my mates shed so I used tig and planishing it flat.
My good helmet was with the mig and the one I had was flashing on and off so that's my excuse, but it's functional.
I used my press and a form tool I had made up for something else to make the pressing for the bolt hole.
I was pleasantly suprised when it fitted.
Other side was similar but not as bad.
Bi-annually?
Once on his birthday and again at Xmas?Straight the rest of the year?
So after picking up and feeding from his mother, with supplemented bottles Thursday, and Friday even putting on a bit of weight, Saturday evening when I got back from the countyshow, he had developed a nasty wheeze, tried steroids and antibiotics through Sunday he deteriorated. His chest sounded like it was half liquid filled and he'd smoked 80 a day for 70 years. So this morning made the tough decision to do the kind thing and put him to sleep. Wasnt easy I can say, real men dont shed a tear, but I did!View attachment 400649
Didnt make this little chap, but delivered him, spent all day trying to get him to stand and feed. Tubed 150mls of goat colostrum into him. Held him while hes had a plasma transfusion, and managed to get him to latch to his mum, but he's still not able to actually get up. So Ill be lifting him to mum every 2 hours through the night!
really very sorry to hear that, its a tough decision but you really did do the best you couldSo after picking up and feeding from his mother, with supplemented bottles Thursday, and Friday even putting on a bit of weight, Saturday evening when I got back from the countyshow, he had developed a nasty wheeze, tried steroids and antibiotics through Sunday he deteriorated. His chest sounded like it was half liquid filled and he'd smoked 80 a day for 70 years. So this morning made the tough decision to do the kind thing and put him to sleep. Wasnt easy I can say, real men dont shed a tear, but I did!
Ahhh noSo after picking up and feeding from his mother, with supplemented bottles Thursday, and Friday even putting on a bit of weight, Saturday evening when I got back from the countyshow, he had developed a nasty wheeze, tried steroids and antibiotics through Sunday he deteriorated. His chest sounded like it was half liquid filled and he'd smoked 80 a day for 70 years. So this morning made the tough decision to do the kind thing and put him to sleep. Wasnt easy I can say, real men dont shed a tear, but I did!
Looks a great job your doing thereToday (well yesterday) I finished welding the Ducato.
I learnt how not to do it from the drivers side and approached the passenger side slightly differently.
Gave myself a bit (lot) more access and cut out the strengthening plate to the top of the strut.
The closure panel is in two parts and I had to weld by braille on the DS.
This time I took out the lower section and made the repair patch the full size so I just had to spot weld it to the lower inner arch.
Easier to weld but still awkward.
Then it was just weld it back up.
I cut a bit extra off the double skin of the top strut plate so I could weld both layers fully.
Then weld the rest back in. I painted some galvafroid to the layers, probably pointless but some might remain after welding.
Bit of white epoxy primer, seam sealer and it's almost there.
Rough and ready but it will keep it going for a few more years.
This side took me about 6 hours from start to finish.
