madkayaker
Pro sparkey Pro Welder
you are welcome to them if you want them! will keep a decent head torch in the cab if i plan to go out after dark
point to note the cluch arms are notorious for allowing the slave cylinder piston to punch through them, usualy when your waiting at a junction or other inopertune moments, but almost never in your drive way
At least with a series LR you can change the clutch by pushing the gearbox back and work inside the cab!
Filler plugs on mine are half inch, made a tool by welding a busted torx socket and spare socket together so the two 1/2" sq recesses face outwards.
Works a treat, after cleaning up the plugs monkeyed by PO's...
I've been wondering how to make on of those
No need to make a tool, just use a 1/2 drive ratchet
...thats why they drip so that when they stop you know its empty
RTB and the rest;
Swap them for Female ones then, they can't be a 50p each![]()
prehaps thats why they drip so that when they stop you know its empty
