Haha, if you were that clever, you might as well fix the actual issue![]()
It would be more on a cost efficiency basis.
You can buy them off eBay for a couple of quid. Just put them in line with the lamp and an ignition feed.If you where really intent then you could put a time delay relay in. My dad had some really compact ones that would work well just soldered 8nto the circuit
‘Some people’ wire them to the oil light, in a pinch.If the light fails to illuminate that is a fail
Quite lucky most of it I can get at from inside the van or drill a hole or two and all will be good got a large supply of grommets on hand.Trickiest part is sometimes just planning out how you are going to treat the inside before you weld in the patches. I’ve boxed myself into a corner on more than one occasion!
I seem to recall someone once telling me that they'd hooked up the ABS light to their oil pressure light, so it did indeed go out when the motor was started.If the light fails to illuminate that is a fail
On my type, the '97 1100r, if the unit fails you just lose ABS. But the later models you mention you can lose just about all braking if the unit fails.The 1150 Beemers with the daft servo-assisted ABS systems were horrible to use and about as reliable as a chocolate welding torch.
So much so that when I bought my (04) Rockster in 07, I deliberately bought a non-ABS variant.
There's an island of the wescht coast of Ireland where no cars are tested.How small does a Scottish Island have to be to be exempt from MOT testing (without a testing station I would think?)
<cough> Timer circuit.If the light fails to illuminate that is a fail
Came home on leave back in the mid 1960's , by the traffic lights at the Stanground turn, an Austin 1100 braked for the red traffic lights and split in two , the front end carrying on & the driver lifting their legs up to stop them getting rubbed off on the roadThere's an island of the wescht coast of Ireland where no cars are tested.
Not been there myself, but from several accounts, a bigger pile of shytty heaps you'd look hard to find, apparently.
I don't suppose it's much of a problem, as the only road is circumferential and is little more than single-track with many bends.
wonder if that was the inspiration behind this part of the The Love BugCame home on leave back in the mid 1960's , by the traffic lights at the Stanground turn, an Austin 1100 braked for the red traffic lights and split in two , the front end carrying on & the driver lifting their legs up to stop them getting rubbed off on the road
I had an Austin A40 Farina just like that. Held together with riveted ally panels and Schutz.Came home on leave back in the mid 1960's , by the traffic lights at the Stanground turn, an Austin 1100 braked for the red traffic lights and split in two , the front end carrying on & the driver lifting their legs up to stop them getting rubbed off on the road
IMO all the R1100/R1150 models with the servo brakes are dodgy as. Mate had a 51-plate mint R1150R with servo ABS, and it packed in when we were right near the top of an Alpine pass descent. Luckily he wasn't steaming into a tight downhill hairpin at the time, but at very low speed.The BMW 1150 RT's with the servo assisted ABS modules are death traps if the electrical servo assist fails.
Another "feature" is you have to remove side panels and petrol tank to top up or blead the brakes, the handlebar reservoir and rear brake reservoir are completely seperate to the fluid that actually operates the calipers. Just a daft setup altogether.
I think there is something like four separate reservoirs, and a ridiculously complicated procedure to bleed the brakes, or change the fluid, scheduled service etc.The BMW 1150 RT's with the servo assisted ABS modules are death traps if the electrical servo assist fails.
If I recall mates bike - there are 2 reservoirs. One of the bars and one under the RHS of the fuel tank.I think there is something like four separate reservoirs, and a ridiculously complicated procedure to bleed the brakes, or change the fluid, scheduled service etc.
Heres a tip. Don't work over an open drain ! What are you thinking of man ? At least put a board over it.Any tips greatly appreciated.
