Join ford ecoboost nightmare on Facebook and see what you think.Guys - I’m seriously worried now.
Mrs. GT has a 2014 1.0 EcoBoost with 29k on it. She’s had it from new and it’s been maintained at the same Ford dealership from new (if indeed that actually counts for much…)
Should I get rid whilst the going is good?
When I worked at a Ford dealer we were paying £450 +vat for them so probably about right.Sure I read some time back that the engine costs Ford something like 300 quid complete?
I've seen that page its quite alarming. but what choice do I have considering that nearly all cars have wet belts.Join ford ecoboost nightmare on Facebook and see what you think.
From what I have been reading the wet belts are failing well within their service interval even in low mileage cars with full ford main dealer service history.
Someone actually commented recently that the company which makes the wetbelts recommends they are changed every 5 years but ford say 10 years, invite disaster but are reluctant to pick up the pieces when disaster strikes.
Ford are often not putting it right either. Some have taken ford to court and won which is cool but doesn't sound like fun.
This is the result of 'engineering by accountants' - regardless of cause, they determined that out-of-warranty repairs would be best served by quickly replacing a major assembly rather than having 'costly' labour intensive repairs where the assembly would need to be disassembled and a large number of 'fit once' components used to return it to service.Have you ever heard anything so ridiculous? It a car ffs not a cheap Chinese 2 stroke strimmer. Did it say in the brochures when new that it comes with a disposable engine that should be replaced every xxx thousand miles?![]()
apart from the conversion thats why they make themif the engine is service correctly the belt should last 10 years so Ford say's.
@johnakay - sell it while it is still running!
then what most cars have wet belts on then.theres no way of getting away from them.
because they know that the wet belt is a bad ideaOn the 1.8's, it's not a conversion kit. It's simply the chain setup, which is a direct swap for the wet belt.apart from the conversion thats why they make thembecause they know that the wet belt is a bad idea
There was a Fiesta 1.0 EcoBoost that, last I heard, was on 170k+ miles on the original belt. Still running sweet as a nut. No oil leaks. It was serviced regularly by a Ford dealership.Guys - I’m seriously worried now.
Wet belts aren't a new idea, our snotty old 1.8 TDCI connect vans had them way back, no problems with them.
Bob
Like most engines, they last longer if used regularly (and serviced regularly) The original oil spec WSS-M2C948-B is susceptible to molecular debonding in the presence of high concentrations of condensation - exactly what happens in a low use, low running temperature vehicle, which is exactly the target market (cost sensitive commuter vehicle) for the ecoboost engined vehicles.There was a Fiesta 1.0 EcoBoost that, last I heard, was on 170k+ miles on the original belt. Still running sweet as a nut. No oil leaks. It was serviced regularly by a Ford dealership.
I can't imagine many first owners buying vehicles with these engines with a view to covering 'sales rep' mileage, the spec levels are 'spartan' in the main, which doesn't encourage long journeys
Sorry mate, no three cylinder engine sounds OK (especially the Smart/Renault engine) - but even worse are the 4 pot with cylinder deactivation, when I was at an Audi dealer, every week we had an A1 or A3 in with a 'misfire'.... I haven't driven any three-potter further than absolutely necessary to give an opinion on the quality of the powertrain or otherwise![]()
Ford messed about with a three cylinder two stroke yonks ago, dont know what happened to that. A mate of mine who worked for the surrey police was given one.
Bob
three cylinder two strokes...
driventowrite.com
3cylinder engines are here to stay I think
