Does the table of your drill rotate around its own centre axis, on an arm which rotates around the column?so just got myself a floor mounted pillar drill
and could do with a vice that can move back and forth once bolted down to the table.
any suggestions or type/brand to look for and ones to avoid..
cheers.
This is a useful warning, but if OP was planning this, all hope is not lost...If you are thinking of using it as a milling machine, remember a drill isn't designed for side loading the bearings
aww thats a shame but thanks for replying.Long gone, I'm afraid. Grim_d had it.
good to know.It was an Axminster.
was it good or ?It was indeed. A CT1.
yes it has a round table supported by an arm off the main column..Does the table of your drill rotate around its own centre axis, on an arm which rotates around the column?
absolutely not, pillar drill is for drilling. and ild use the mill if i could get to it lolIf you are thinking of using it as a milling machine, remember a drill isn't designed for side loading the bearings
If you have a round table that rotates though, there is no need.aww thats a shame but thanks for replying.
good to know.
was it good or ?
as that has x,y table. not as much height clearance the floor mounted pillar drill has.
but much more then the little bench top pillar drill i got.
the idea of putting an x,y table or compound slide vice on the pillar drill is.
i can fix it down to the round table and slide the metal into the vice.
and move the vice back/forth and side to side until i got the centre drill bang on the centre punch mark.
lock the vice and drill the hole.
i got some plastic gantry plates on a laser engraver and i want to remake them out of ali and slightly bigger to take a bigger top extrusion.
also means replacing the others to take a 60 or 80mm high extrusion as its currently 2020.
so the holes need to be spot on..
also need to sort the Z axis as the play is shocking and make it higher so i can use with laser or plasma torch.
You need a combination of rotating the table, and rotating the table mount in the column.i dont see how that will work. you clamp the workpiece to the table and the table will rotate but your work piece will rotate at the set circumference, your not be able to find tune its position.
and like i said the holes need to be bang on. as the plates are for cnc frame.
...your work piece will rotate at the set circumference, you will not be able to fine tune its position.
that is true i guess. but i know having all that overhang on a drill press for me, il end up knocking it all the time.The thing I like about my CT1 is that its got space to put bits and bobs on as well as a vice.
This is especially useful if you have a freestanding drill.
that does look good, but a lot of machining to make..... on a mill i cant get too right now.Have a look at the latest YT from Pask Makes. He has just shown a clamp that goes around the column, with a bar attached to it that is also attached to the vise.
The clamp allows rotational movement and the bar allows radial movement. In effect, you convert your rectangular (x,y) coordinates into polar (r, theta) coordinates. Same principle as a proper radial drill.
A laser pointer can be used to line it all up as its 'length' is variable. If you use a fixed pointy thing in the chuck to line it up, you lose alignment when you have to raise the head to insert a much longer drill bit.
