The main guy for diy small wind tubines is Hugh PiggottI'm not sure this is the right site but it's the only one I can find.... http://www.windandwet.com/index.php
it might be the right guy..... there's a "wind turbine guy" who's an expert at diy small wind turbines, knows them inside out
this designs have special tail, which turn the turbine blades out of the wind when the wind gets too fast.... saving you from having to have a system to brake it and also letting it generate in higher winds
can;t find it but there's another side (maybe someone here will know it?) when you can put in your post code and it'll tell you the average wind speed at different heights from the ground.... helps figure out if it's worth making one
for best output/efficiency you need to me 6m above any buildings/trees etc.
ah that's the guy!The main guy for diy small wind tubines is Hugh Piggott
Many of the contributors to the Navitron site are now here including Clockmanfr who has build several of Hugh's design wind turbines and some PV trackers.
Gaz1, not sure if this will be of any use to you but see below my figures since my system went in.@J1nx
@brewdexta
since weve just gone through a winter would you state what you have installed
how many solar panels in use
your power output from your solar panels
is your panels in the optimum position
would you both mind showing your winter power outputs for the winter both daily and monthly if possible
to be honest i would like to see both of your power outputs between southern and mid north solar collection ( mid north is hull to blackpool range to me )
thankyou for posting as that will provide the numbers for north ( aberdeen ) for solar usageGaz1, not sure if this will be of any use to you but see below my figures since my system went in.
Garage is 3.87KWp (50 degree angle) and caravan port is 10.24kWp (8 degree angle), bit further north than you are looking for so anything comparative is likely to give higher outputs.
@J1nx
@brewdexta
not true got mine done in December last year and haven't paid a penny in elec,201 in creditOct to March you will generate didlysquat, or thereabouts. Unless the weather turns clear and cold.
Well done nonetheless.
Ha, and how much money have the g.ment put into your account?not true got mine done in December last year and haven't paid a penny in elec,201 in credit
Average daylight in UK latitude is I believe a little under 11-hrs-a-day. However, in winter the "daylight" as MM says ain't up to much - but you might be lucky and do maybe 5%?I did do a fag packet calculation on payback and assumed 80% for 6 months (optimistic) and 0% for 6 months. Whilst 80% may be optimistic for 3 of those 6 I have no real data to go on, however the 80% above includes last Friday which was on solar, so actual savings last week were above that and at current cost of 28p/kWh.
I think I will struggle to get any FIT due to no MCS, but I will try just in case when I renew contract (staying on price cap is better than FIT at 7.5p anyway).
The last line graph I posted shows current consumption/generation, as you can see we are now achieving almost 100% and as I have data from last June onwards we should easily now continue that through to September.Average daylight in UK latitude is I believe a little under 11-hrs-a-day. However, in winter the "daylight" as MM says ain't up to much - but you might be lucky and do maybe 5%?
(So many variables & I'm working on anecdotal info not personal direct).
Dunno where you are, but the summer period still has dark, cloudy, cruddy days (esp. here in West Wales), so yeah, I'd think 80% is very optimistic (unless we get another 1976). 50% maybe?
