GrahamGKD
My RCD in the house started tripping out the other day when I was doing some plasma cutting. I assumed it was the plasma m/c and sent that back to be checked but then realised I was getting the same problem with my Portamig plugged into the 32A socket I use for the plasma. I have thoroughly cleaned the socket and did a whole load more MIGing this morning without problem but I just went and took a shower and it tripped again. Could it be that the RCD has become over sensitive when under high load? This is a bit of a worry as we don't have the 17th edition split consumer unit - just one RCD for the whole lot, including the freezer. Options I can think of are to replace the RCD in the house or fit a more sensitive RCD in the consumer unit in my workshop? I guess I could isolate the workshop when not in use to see if I get any further trips in the house with the workshop isolated? Could an earth loop (e.g. SWA to workshop armour used as an earth conductor as well as one of the cores inside) cause this kind of problem - I can't see how it would?
I’d appreciate some help on this one please.
Cheers,
Graham.
Cheers,
Graham.
other than that its just guess work which is no use atall
