No welding, upholstery.If you are welding in it would it be worth using a fire retardant paint?
The same as I've done previously with new plaster finishes in that case.when we've painted raw OSB with emulsion numerous times & the board absorbs the 1st coat loads. Suggest you water the 1st coat down & then continue with full-strength coats until you're happy with the finish.
