Cato
- Birmingham, UK
I've made a bogey frame (welding was involved!) for moving the Ski-Doo about while it's being stripped. However when that's done, or possibly before, the idea is to make it into a mobile bench. It'll be multi-purpose, welding, grinding, laying out, stripping engines etc. Dirty stuff, and also things that may need a bit of bashing as well as placing some heavy things on it. The frame is 80 x 80 x 5mm box section sitting on castors rated for 150kg each giving me 600 kg max, which is likely to be 100% more than the heaviest thing I'd be likely to have on it.
The other main bench in the workshop is set at a comfortable 900mm high, but as the mobile bench is for very different work I'm wondering if this should be lower? If I'm working on something like an engine which sits 300 - 450 mm high the top of it will be too high to work on comfortably. Lower stuff like welding something up will be lower but I tend (rightly or wrongly) to be more comfortable working 'over' something like that.
I'm sure loads of you have a bench for this sort of stuff, so what height do you recommend based on what you're using?
