Finally got to use my r-tech 180 mig this week, after sorting setting up error ( forgot contact tip
) I did a couple of test runs that came out really well. Then went on to repair some 12mmm plate, I put a rough 2.5mm bevel on each side turned power to full and set wire speed to around 3/4, bloody hell it punched all the way through.
The job I had allowed a day to do was done in under two hours
First time using a mig properly and it was way easier and quicker than stick.
And off a 13a plug as well
) I did a couple of test runs that came out really well. Then went on to repair some 12mmm plate, I put a rough 2.5mm bevel on each side turned power to full and set wire speed to around 3/4, bloody hell it punched all the way through.The job I had allowed a day to do was done in under two hours
.First time using a mig properly and it was way easier and quicker than stick.
I am disgusted with you
